OPPO
Reno13 Pro 5G
OPPO Reno13 Pro 5G
f-13069daf-491c-4ee3-b6f2-59c91fdd0d40
f-3e62d185-07c1-45d5-a223-a858ba2e954f
f-635c0ea8-039d-4a3e-b9d7-348e841b3185
f-b5b0f668-db02-49a2-8869-ac9ff7db426e
f-e8f2b068-f303-4f4f-b594-9a10efabb9e6
f-031192c4-64ef-4262-a251-fd014ae628e5
f-a9403534-daee-477f-b675-0098ba384b73
f-0ef9a2a9-38d4-4cc1-b21b-eff492a1dd39
Using Gemini on your phone
You can use Gemini to generate text, create various creative content and answer your questions in an informative way. Here you can see some examples of Gemini usage. To use most of the Gemini functions, you need to activate your Google account on your phone and set up your phone for internet.
Step 1 of 40
Press Gemini. If prompted, follow the instructions on the screen to turn on the function.
Step 2 of 40
Press the profile icon.
Step 3 of 40
Step 4 of 40
Follow the instructions on the screen to select the required settings.
Step 5 of 40
Step 6 of 40
Press Apps.
Press Apps.
Step 7 of 40
Press Apps.
Press the indicator next to the required extension to turn on the function.
Step 8 of 40
If you turn on extensions, Gemini can interact with other apps and services to give you answers to your questions and respond to your commands for the selected app or service.
Press arrow left to return to Gemini.
Step 9 of 40
Follow the instructions on the screen to type or speak the required question. You can also attach pictures or documents and ask questions to them.
Step 10 of 40
The answer from Gemini to your question is displayed.
Step 11 of 40
Press the speaker icon to play back the answer from Gemini.
Step 12 of 40
Follow the instructions on the screen to type or speak more questions to continue the conversation.
Step 13 of 40
You can ask Gemini to generate a text based on your description.
Step 14 of 40
You can also ask Gemini to generate a picture based on your description.
Step 15 of 40
Press arrow left to leave the conversation.
Step 16 of 40
Press the Gemini Live icon. If prompted, follow the instructions on the screen to turn on the function.
Step 17 of 40
Talk to Gemini about the required topic.
Step 18 of 40
You can have a direct conversation with Gemini without having to write anything.
To pause the conversation, press the pause icon.
Step 19 of 40
To resume the conversation, press the resume icon.
Step 20 of 40
To end the conversation, press the end icon.
Step 21 of 40
Transcription of the conversation with Gemini Live is now displayed.
Step 22 of 40
Step 23 of 40
Open the Messages.
Open the Messages.
Step 24 of 40
Open the Messages.
Gemini can generate text suggestions based on the selected topic.
Step 25 of 40
Press Messages settings.
Step 26 of 40
Press Gemini in Messages.
Step 27 of 40
Step 28 of 40
Press the indicator next to "Show Gemini Button" to turn on the function.
Press arrow left the necessary number of times to return to the list of messages.
Step 29 of 40
Press the Gemini icon. If prompted, follow the instructions on the screen to turn on the function.
Step 30 of 40
Write or say in your own words which topic you would like to use.
Step 31 of 40
To use one of the predefined topics, press a topic example.
Step 32 of 40
The text suggestion from Gemini is displayed.
Step 33 of 40
Press and hold the text suggestion from Gemini. Follow the instructions on the screen to use the text suggestion.
Step 34 of 40
Open YouTube and go to the required video.
Step 35 of 40
Using Gemini, you can ask questions about the content of a YouTube video.
Press and hold the Side key to activate Gemini.
Step 36 of 40
If you've turned on automatic activation, you can say "Hey Google" to activate Gemini.
Press Ask about video.
Step 37 of 40
Follow the instructions on the screen to type or speak the required question for the video.
Step 38 of 40
Step 39 of 40
Slide your finger right starting from the left side of the screen to return to the video.
Step 40 of 40
