OPPO
Reno8 5G
OPPO Reno8 5G
f-5dcec46d-939d-48da-a3b8-379a596beb3e
f-5692557d-4ca8-4fef-b912-144ff5022f2d
f-27daa849-02e2-460a-9d32-fbbaf4d8d157
f-3cd3a3f1-69c2-4fbf-b435-805679f549b8
f-3b400d1f-3e6f-4ce6-8785-5e035935c235
f-4122ed3c-b11f-4c4b-b100-c9131d41878f
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
