OPPO Reno8 Pro 5G
Importing contacts from your SIM to your phone
You can import your contacts from your SIM to your phone. This way, you won't lose your contacts if you change your SIM.
Press Contacts.
Press Fix & manage.
Press Import from SIM.
Press the required SIM.
Press OK.
Press the drop down list next to "Save to".
Press Device.
Press the fields next to the required contacts.
Press Import.
Press Keep to keep the existing contacts on your SIM.
Press Remove to delete the existing contacts on your SIM.
