OPPO
Reno8 Pro 5G
OPPO Reno8 Pro 5G
f-4578d57a-aca2-4d7f-a4ef-62a28d2e27ff
f-63c74fb3-b5e6-4c0c-9b1c-e293d03d0338
f-09fda53e-3e24-418a-aa69-150b7fa2026a
f-f6b9ebbc-e1f4-40bd-af52-e45b5db6c688
f-b95806ea-04bf-41d7-880c-0712ca672b89
f-3db8c68e-7fdd-46a2-be31-7a78538b681d
Solution 2 of 2: Wi-Fi hotspot isn't used correctly
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Step 1 of 16
Step 2 of 16
Press Connection & sharing.
Step 3 of 16
Press Personal hotspot.
Step 4 of 16
Press Hotspot settings.
Step 5 of 16
Press the field below
Step 6 of 16
Press the field below "Hotspot name (required)" and key in the required name.
Press Security.
Press Security.
Step 7 of 16
Press Security.
Press WPA3-Personal to password protect your Wi-Fi hotspot.
Step 8 of 16
Step 9 of 16
Press the field below "Password" and key in the required password.
Press the save icon.
Step 10 of 16
Press the indicator below
Step 11 of 16
Press the indicator below "Personal hotspot" to turn on the function.
Step 12 of 16
OPPO Reno8 Pro 5G
OPPO Reno8 Pro 5G
Step 13 of 16
OPPO Reno8 Pro 5G
OPPO Reno8 Pro 5G
Step 14 of 16
OPPO Reno8 Pro 5G
OPPO Reno8 Pro 5G
Step 15 of 16
OPPO Reno8 Pro 5G
OPPO Reno8 Pro 5G
Step 16 of 16
