OPPO
Reno8 Pro 5G
OPPO Reno8 Pro 5G
f-4578d57a-aca2-4d7f-a4ef-62a28d2e27ff
f-63c74fb3-b5e6-4c0c-9b1c-e293d03d0338
f-09fda53e-3e24-418a-aa69-150b7fa2026a
f-f6b9ebbc-e1f4-40bd-af52-e45b5db6c688
f-b95806ea-04bf-41d7-880c-0712ca672b89
f-3db8c68e-7fdd-46a2-be31-7a78538b681d
Turning GPS on or off
Step 1 of 15
Step 2 of 15
Press Location.
Press Location.
Step 3 of 15
Press Location.
Step 4 of 15
Press the indicator next to "Location" to turn the function on or off.
If you turn on geotagging, your phone can find your position using GPS. If you turn off the function, you can't use any GPS functions on your phone.
Press Google Location Accuracy.
Step 5 of 15
Step 6 of 15
Step 7 of 15
Press the Return key twice.
Step 8 of 15
Press Apps.
Press Apps.
Step 9 of 15
Press Apps.
Press App management.
Step 10 of 15
Press the required app.
Step 11 of 15
Press Permissions.
Press Permissions.
Step 12 of 15
Press Permissions.
Press Location.
Press Location.
Step 13 of 15
Press Location.
Press the required setting.
Step 14 of 15
Step 15 of 15
