Galaxy A05s
Samsung Galaxy A05s
f-38a0c227-9c25-4711-8baa-02245d9848dd
f-12d5fc62-c91a-49e8-a96c-782261707acd
f-19f0c9aa-88a2-42a0-950f-9dfcc3cea7e0
f-dea4fa47-e0cf-476d-904b-362d50b499d5
f-3f9a9eb9-2480-4fc8-94f3-162817f9b5f8
f-4508f9f7-759a-47b7-b04b-de9ab43746eb
Solution 6 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
