Galaxy A05s
Samsung Galaxy A05s
f-38a0c227-9c25-4711-8baa-02245d9848dd
f-12d5fc62-c91a-49e8-a96c-782261707acd
f-19f0c9aa-88a2-42a0-950f-9dfcc3cea7e0
f-dea4fa47-e0cf-476d-904b-362d50b499d5
f-3f9a9eb9-2480-4fc8-94f3-162817f9b5f8
f-4508f9f7-759a-47b7-b04b-de9ab43746eb
Solution 1 of 4: Wi-Fi calling is turned off
When Wi-Fi calling is turned on, you can make and answer calls using a Wi-Fi network when you're in an area with little or no network coverage. To turn on Wi-Fi calling, you need to establish a connection to a Wi-Fi network, select 4G (LTE) as network mode and follow the steps below. You can also visit the EE web page for more information about Wi-Fi calling.
Step 1 of 5
Step 2 of 5
Press Connections.
Press Connections.
Step 3 of 5
Press Connections.
Step 4 of 5
Press the indicator next to "Wi-Fi Calling" to turn the function on or off.
Step 5 of 5
