Samsung Galaxy A13
Solution 1 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
