Galaxy A13
Samsung Galaxy A13
f-8664d37a-0ca3-44a3-af79-d819daef5a83
f-1074e5a4-01a0-4d71-a081-a49239377aa4
f-e075fc43-46d2-4dc4-a496-a6f3da6043f0
f-992f1660-2bd3-4a27-9373-328893a18633
f-1663caf3-4661-4284-a336-ba85527a400f
f-0d87f245-ec9c-44cc-9339-c17093a08f6b
Can you make a voice call?
