Galaxy A14 5G
Samsung Galaxy A14 5G
f-7bd02f1e-1ca3-40ba-8fb6-16ace2d18b48
f-83e22f2d-bf6e-4954-9845-c01ae4659420
f-e7962994-440f-4fcc-a0fa-0588f390bb2c
f-870e1704-a63c-4060-bfe8-d4ca01085e46
f-6b5f509d-fb67-4a12-a242-2620a983a7bc
f-54781426-4baa-4418-99bd-7b2765a3075d
Can you make a voice call?
