Samsung Galaxy A14 5G
Selecting dual SIM settings
When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Press Connections.
Press SIM manager.
Press the required SIM.
Press the indicator to turn use of the SIM on or off.
If you turn on use of the SIM, press OK.
If you turn off use of the SIM, press Turn off.
Press the Return key.
Press Calls.
Press the required setting.
Press Messages.
Press Mobile data.
