Galaxy A15 5G
Samsung Galaxy A15 5G
f-51e7f5d4-819c-4cd1-8cd5-ea7528838911
f-b35a67de-818f-4c9d-a6a8-d138edec42d6
f-18971f31-7df2-4edf-bb3b-12c78cda2874
f-6cc37974-9b9a-439b-84d4-f63f4b9244af
f-07767e6d-806c-475b-bb4d-a28adaa4b613
f-ba46e8e6-0494-4ca0-b5b5-684d622c172e
f-68ea40cd-f738-408b-83d0-825ac401c9d9
f-7e3d06a2-74ee-4c38-a55f-5f0f66eef75a
Can you make a voice call?
