Samsung Galaxy A15
![f-51e7f5d4-819c-4cd1-8cd5-ea7528838911](http://wmstatic.global.ssl.fastly.net/ml/020724-f-51e7f5d4-819c-4cd1-8cd5-ea7528838911.png?width=140&height=200)
![f-b35a67de-818f-4c9d-a6a8-d138edec42d6](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b35a67de-818f-4c9d-a6a8-d138edec42d6.png?width=140&height=200)
![f-18971f31-7df2-4edf-bb3b-12c78cda2874](http://wmstatic.global.ssl.fastly.net/ml/020724-f-18971f31-7df2-4edf-bb3b-12c78cda2874.png?width=140&height=200)
![f-6cc37974-9b9a-439b-84d4-f63f4b9244af](http://wmstatic.global.ssl.fastly.net/ml/020724-f-6cc37974-9b9a-439b-84d4-f63f4b9244af.png?width=140&height=200)
![f-07767e6d-806c-475b-bb4d-a28adaa4b613](http://wmstatic.global.ssl.fastly.net/ml/020724-f-07767e6d-806c-475b-bb4d-a28adaa4b613.png?width=140&height=200)
![f-ba46e8e6-0494-4ca0-b5b5-684d622c172e](http://wmstatic.global.ssl.fastly.net/ml/020724-f-ba46e8e6-0494-4ca0-b5b5-684d622c172e.png?width=140&height=200)
![f-68ea40cd-f738-408b-83d0-825ac401c9d9](http://wmstatic.global.ssl.fastly.net/ml/020724-f-68ea40cd-f738-408b-83d0-825ac401c9d9.png?width=140&height=200)
![f-7e3d06a2-74ee-4c38-a55f-5f0f66eef75a](http://wmstatic.global.ssl.fastly.net/ml/020724-f-7e3d06a2-74ee-4c38-a55f-5f0f66eef75a.png?width=140&height=200)
Using music player
You can use the music player to play audio files you have transferred to your phone.
![Slide your finger upwards on the screen. Slide your finger upwards on the screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b98be273-1ac3-4bfe-9946-256b162eb091.png?width=232&height=502)
![Slide your finger upwards on the screen. Slide your finger upwards on the screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b98be273-1ac3-4bfe-9946-256b162eb091.png?width=344&height=744)
![Press YT Music. Press YT Music.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-f3ffd657-2759-4866-8808-9df16a404a3b.png?width=232&height=502)
![Press YT Music. Press YT Music.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-f3ffd657-2759-4866-8808-9df16a404a3b.png?width=344&height=744)
Press YT Music.
![Press Library. Press Library.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-f8bf51fc-3d27-4087-9482-9cb41595819b.png?width=232&height=502)
![Press Library. Press Library.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-f8bf51fc-3d27-4087-9482-9cb41595819b.png?width=344&height=744)
Press Library.
![Press the drop down list. Press the drop down list.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-07c58c8a-23e5-42f9-a5e4-d1c1ad908e80.png?width=232&height=502)
![Press the drop down list. Press the drop down list.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-07c58c8a-23e5-42f9-a5e4-d1c1ad908e80.png?width=344&height=744)
![Press the required category and go to the required audio file. Press the required category and go to the required audio file.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-74b9b871-b9c0-4c9c-ba88-c0b1bc0bd2ea.png?width=232&height=502)
![Press the required category and go to the required audio file. Press the required category and go to the required audio file.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-74b9b871-b9c0-4c9c-ba88-c0b1bc0bd2ea.png?width=344&height=744)
![Press the required audio file. Press the required audio file.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-78c37a07-dd71-464f-abd7-00647dd5dfb5.png?width=232&height=502)
![Press the required audio file. Press the required audio file.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-78c37a07-dd71-464f-abd7-00647dd5dfb5.png?width=344&height=744)
Press the upper or lower part of the Volume key to adjust the volume.
![Press arrow right to go to the next audio file. Press arrow right to go to the next audio file.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=232&height=502)
![Press arrow right to go to the next audio file. Press arrow right to go to the next audio file.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=344&height=744)
![Press arrow left twice to go to the previous audio file. Press arrow left twice to go to the previous audio file.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=232&height=502)
![Press arrow left twice to go to the previous audio file. Press arrow left twice to go to the previous audio file.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=344&height=744)
![Press the repeat icon to turn the function on or off. Press the repeat icon to turn the function on or off.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=232&height=502)
![Press the repeat icon to turn the function on or off. Press the repeat icon to turn the function on or off.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=344&height=744)
![Press the shuffle icon to turn the function on or off. Press the shuffle icon to turn the function on or off.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=232&height=502)
![Press the shuffle icon to turn the function on or off. Press the shuffle icon to turn the function on or off.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=344&height=744)
![Press the menu icon. Press the menu icon.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=232&height=502)
![Press the menu icon. Press the menu icon.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=344&height=744)
![Press the add icon. Press the add icon.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-e94c5047-655a-446a-a77e-0a0d030c7cf2.png?width=232&height=502)
![Press the add icon. Press the add icon.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-e94c5047-655a-446a-a77e-0a0d030c7cf2.png?width=344&height=744)
Press the add icon.
![Press Create a new playlist. Press Create a new playlist.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b52329da-3b27-481f-915d-c53ea7034f54.png?width=232&height=502)
![Press Create a new playlist. Press Create a new playlist.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b52329da-3b27-481f-915d-c53ea7034f54.png?width=344&height=744)
![Key in a name for the playlist and press Create. Key in a name for the playlist and press Create.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-9fd59c99-0c89-4c50-9035-770283053e31.png?width=232&height=502)
![Key in a name for the playlist and press Create. Key in a name for the playlist and press Create.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-9fd59c99-0c89-4c50-9035-770283053e31.png?width=344&height=744)
![Press the Home key to return to the home screen. Press the Home key to return to the home screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=232&height=502)
![Press the Home key to return to the home screen. Press the Home key to return to the home screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-85dde901-3590-4909-856c-01fb5e15af20.png?width=344&height=744)
