Samsung Galaxy A15
![f-51e7f5d4-819c-4cd1-8cd5-ea7528838911](http://wmstatic.global.ssl.fastly.net/ml/020724-f-51e7f5d4-819c-4cd1-8cd5-ea7528838911.png?width=140&height=200)
![f-b35a67de-818f-4c9d-a6a8-d138edec42d6](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b35a67de-818f-4c9d-a6a8-d138edec42d6.png?width=140&height=200)
![f-18971f31-7df2-4edf-bb3b-12c78cda2874](http://wmstatic.global.ssl.fastly.net/ml/020724-f-18971f31-7df2-4edf-bb3b-12c78cda2874.png?width=140&height=200)
![f-6cc37974-9b9a-439b-84d4-f63f4b9244af](http://wmstatic.global.ssl.fastly.net/ml/020724-f-6cc37974-9b9a-439b-84d4-f63f4b9244af.png?width=140&height=200)
![f-07767e6d-806c-475b-bb4d-a28adaa4b613](http://wmstatic.global.ssl.fastly.net/ml/020724-f-07767e6d-806c-475b-bb4d-a28adaa4b613.png?width=140&height=200)
![f-ba46e8e6-0494-4ca0-b5b5-684d622c172e](http://wmstatic.global.ssl.fastly.net/ml/020724-f-ba46e8e6-0494-4ca0-b5b5-684d622c172e.png?width=140&height=200)
![f-68ea40cd-f738-408b-83d0-825ac401c9d9](http://wmstatic.global.ssl.fastly.net/ml/020724-f-68ea40cd-f738-408b-83d0-825ac401c9d9.png?width=140&height=200)
![f-7e3d06a2-74ee-4c38-a55f-5f0f66eef75a](http://wmstatic.global.ssl.fastly.net/ml/020724-f-7e3d06a2-74ee-4c38-a55f-5f0f66eef75a.png?width=140&height=200)
Using your phone as Wi-Fi hotspot
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
![Slide two fingers downwards starting from the top of the screen. Slide two fingers downwards starting from the top of the screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b98be273-1ac3-4bfe-9946-256b162eb091.png?width=232&height=502)
![Slide two fingers downwards starting from the top of the screen. Slide two fingers downwards starting from the top of the screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b98be273-1ac3-4bfe-9946-256b162eb091.png?width=344&height=744)
![Press the settings icon. Press the settings icon.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-9c5221b0-14c2-49ba-8a36-d8875027d3a4.png?width=232&height=502)
![Press the settings icon. Press the settings icon.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-9c5221b0-14c2-49ba-8a36-d8875027d3a4.png?width=344&height=744)
![Press Connections. Press Connections.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-aa5c52e6-4e0c-4aa7-a7cb-05bc97c4397b.png?width=232&height=502)
![Press Connections. Press Connections.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-aa5c52e6-4e0c-4aa7-a7cb-05bc97c4397b.png?width=344&height=744)
Press Connections.
![Press Mobile Hotspot and Tethering. Press Mobile Hotspot and Tethering.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-36df2bd1-f9be-4085-93c5-e532c67c072b.png?width=232&height=502)
![Press Mobile Hotspot and Tethering. Press Mobile Hotspot and Tethering.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-36df2bd1-f9be-4085-93c5-e532c67c072b.png?width=344&height=744)
![Press Mobile Hotspot. Press Mobile Hotspot.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-21d55c85-5bb8-435f-811b-6b6eeb966aa9.png?width=232&height=502)
![Press Mobile Hotspot. Press Mobile Hotspot.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-21d55c85-5bb8-435f-811b-6b6eeb966aa9.png?width=344&height=744)
![Press Network name. Press Network name.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-026caedc-798a-4d1a-a12a-6445631635be.png?width=232&height=502)
![Press Network name. Press Network name.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-026caedc-798a-4d1a-a12a-6445631635be.png?width=344&height=744)
Press Network name.
![Press the field below Press the field below](http://wmstatic.global.ssl.fastly.net/ml/020724-f-c300afca-2fb6-400e-9b5b-f83203995912.png?width=232&height=502)
![Press the field below Press the field below](http://wmstatic.global.ssl.fastly.net/ml/020724-f-c300afca-2fb6-400e-9b5b-f83203995912.png?width=344&height=744)
Press the field below "Network name" and key in the required name.
![Press Security. Press Security.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-c300afca-2fb6-400e-9b5b-f83203995912.png?width=232&height=502)
![Press Security. Press Security.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-c300afca-2fb6-400e-9b5b-f83203995912.png?width=344&height=744)
Press Security.
![Press WPA3-Personal to password protect your Wi-Fi hotspot. Press WPA3-Personal to password protect your Wi-Fi hotspot.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-862f3d75-59c2-48ae-b36e-a03b9795579d.png?width=232&height=502)
![Press WPA3-Personal to password protect your Wi-Fi hotspot. Press WPA3-Personal to password protect your Wi-Fi hotspot.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-862f3d75-59c2-48ae-b36e-a03b9795579d.png?width=344&height=744)
![Press the field below Press the field below](http://wmstatic.global.ssl.fastly.net/ml/020724-f-4b7ea336-f3f3-412d-aab9-8e8a0b9df665.png?width=232&height=502)
![Press the field below Press the field below](http://wmstatic.global.ssl.fastly.net/ml/020724-f-4b7ea336-f3f3-412d-aab9-8e8a0b9df665.png?width=344&height=744)
Press the field below "Password" and key in the required password.
![Press Save. Press Save.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-11a8009b-b7a9-4b54-b25a-b7340f99d804.png?width=232&height=502)
![Press Save. Press Save.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-11a8009b-b7a9-4b54-b25a-b7340f99d804.png?width=344&height=744)
Press Save.
![Press the indicator below Press the indicator below](http://wmstatic.global.ssl.fastly.net/ml/020724-f-026caedc-798a-4d1a-a12a-6445631635be.png?width=232&height=502)
![Press the indicator below Press the indicator below](http://wmstatic.global.ssl.fastly.net/ml/020724-f-026caedc-798a-4d1a-a12a-6445631635be.png?width=344&height=744)
Press the indicator below "Mobile Hotspot" to turn on the function.
![Press Turn off. Press Turn off.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b8c2ef41-2ce4-48b0-87ce-d0ddebcabf04.png?width=232&height=502)
![Press Turn off. Press Turn off.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-b8c2ef41-2ce4-48b0-87ce-d0ddebcabf04.png?width=344&height=744)
Press Turn off.
![Press the Home key to return to the home screen. Press the Home key to return to the home screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-70a32695-b432-4439-b4e0-b9fb9e12b196.png?width=232&height=502)
![Press the Home key to return to the home screen. Press the Home key to return to the home screen.](http://wmstatic.global.ssl.fastly.net/ml/020724-f-70a32695-b432-4439-b4e0-b9fb9e12b196.png?width=344&height=744)
![Samsung Galaxy A15 Samsung Galaxy A15](http://wmstatic.global.ssl.fastly.net/ml/020724-f-7918d301-4203-4875-b220-3f38a6049d30.png?width=520&height=540)
![Samsung Galaxy A15 Samsung Galaxy A15](http://wmstatic.global.ssl.fastly.net/ml/020724-f-7918d301-4203-4875-b220-3f38a6049d30.png?width=540&height=800)
