Galaxy A16 4G
Samsung Galaxy A16 4G
f-5b532328-c0d4-403a-bae8-02fc38b3952d
f-13e4350f-7815-40df-836b-f6ecb52a65d1
f-686f2be1-f2a8-447b-b6e2-0661a36824ba
f-c349d311-fee0-4a84-9956-2ddde04e0f47
f-a0b45309-e9fb-41f0-8a4c-7ae5c0bad923
f-bc16b161-f9fc-4af2-9600-c31b76312f7a
f-a27ca1bd-81b2-4115-9cd4-71274a315f3f
f-dd02f5ec-f00a-4029-9917-4d10a2dabbc3
Selecting ring tone
You can select the ring tone you want to hear when you get a call.
Press Sounds and vibration.
Press Ringtone.
Press Ringtone.
Press Ringtone.
Press the required ring tones to hear them.
Once you've found a ring tone you like, press the Return key.
To use a different ring tone than the default ones, press the add ring tone icon and follow the instructions on the screen to select the required ring tone.
