Galaxy A16 5G
Samsung Galaxy A16 5G
f-c9848985-22d2-4fa5-948b-469e3da52849
f-d5bb565a-0ed7-4378-a64e-156ef6f49276
f-cfe96e67-c97d-4c7b-899b-48816b7d1e7d
f-264457c0-87b2-4f4b-a0b9-c044ebb177e6
f-5188aec5-a73f-44f4-86a6-82df780be186
f-a9de837f-5423-4cf3-bbfb-3c7026912a7f
f-b8e7be56-5448-48bf-a927-07aca342c99f
f-607db3e3-a11d-4840-b92b-18784396c80c
Selecting ring tone
You can select the ring tone you want to hear when you get a call.
Press Sounds and vibration.
Press Ringtone.
Press Ringtone.
Press Ringtone.
Press the required ring tones to hear them.
Once you've found a ring tone you like, press the Return key.
To use a different ring tone than the default ones, press the add ring tone icon and follow the instructions on the screen to select the required ring tone.
