Galaxy A22 5G
Samsung Galaxy A22 5G
f-983ea3d4-3376-4750-bcca-0208efc3054b
f-d3b12d2d-08f2-4866-bbbc-b2a2ba07f500
f-651dd4c9-c885-4612-94d9-56c3db0f7a7e
f-28d9be96-930f-42cd-a28f-5cb25f185eca
f-7a759d0a-aaf0-4579-9767-3f62a602232d
f-c9c708fc-3436-4af7-95df-19aeee519a8d
Can you make a voice call?
