Galaxy A23 5G
Samsung Galaxy A23 5G
f-ec8a7bfd-d5e1-4a77-b584-46172bbaab0c
f-eb9b8560-5f08-4dd5-bd73-5f3a201447d6
f-db11d9c9-1c30-456f-85c7-eb55b3c76a29
f-b967662f-978c-424c-8dec-a4e4f7d4eea4
f-5bc2bcf7-77a2-4ba5-8ff5-1feebb67980e
f-54a8596b-f36f-4727-8407-46f0c7b76be8
Can you use Wi-Fi?
