Galaxy A25 5G
Samsung Galaxy A25 5G
f-516a9adb-f65a-4024-8990-32d7cc16c3a8
f-a21110ff-aced-4c16-822b-ec8a883a0f8e
f-c0d4ec78-3e49-450d-b6e2-8f4251b63ed5
f-6cf81005-6e66-432d-98ed-30208171d6fb
f-427ea6aa-23c0-4b84-8c0d-f17514f090d6
f-2a5e7b1f-93f3-4376-8b1e-d0b2afba2579
Can you make a voice call?
