Galaxy A26 5G
Samsung Galaxy A26 5G
f-42db3f48-a9bb-4f2d-ae64-3054ebb88068
f-fd54c792-bc59-4177-b200-61cf152aa73b
f-b708b726-c7a3-4fda-8444-f2d1d50d6610
f-eab05177-5eef-47ba-8480-f969897df007
f-cb32c6bd-c002-4a4d-bd78-3aeb401cf233
f-6fbea3aa-f449-4e10-8205-af346dba0d7c
f-5121e09d-c9f2-484e-8809-6df168e6a809
f-95a9a378-6e79-48fa-b9d5-399fadd9824e
Can you make a voice call?
