Galaxy A32 5G
Samsung Galaxy A32 5G
f-e73f0d2c-81c2-4bef-909c-cb474d80b3c9
f-d9a22f9c-0a71-4f9d-b731-cc64320e34de
f-977678bc-7fb5-459c-b139-00347c06f41f
f-c51bd060-4c37-4052-8594-36b21ffaf0a5
f-42d78bd0-67ba-43bc-b0f1-aec5df4e9d03
f-4d97f6c6-603e-41e8-a033-0448247a2c64
Can you make a voice call?
