Galaxy A34 5G
Samsung Galaxy A34 5G
f-b1f7f99d-3cb8-43bd-b17e-1e8b2c6b6c03
f-8db9579f-caf8-4bf0-9751-6cb02a4148e0
f-9e635dd1-6827-4222-b9d1-45c2a563fc82
f-b539eb38-7635-4aa8-9fdf-30b21d703a7d
f-b1cc0f72-aca0-4b23-bb60-04ca596691f0
f-968cdeb2-bb10-46fa-a4dd-de0f9477c3f1
Can you make a voice call?
