Galaxy A35
Samsung Galaxy A35
f-113b4e9d-2605-4aee-b521-e95b3007b714
f-234caf96-25e2-4f27-aeaf-ee2ab2ff2e40
f-fda06747-b9ec-4823-ab5b-ab81a5fd2692
f-1da8db16-1ae1-471e-bde1-53bb1038e5f2
f-9c3f76af-d277-4bfc-b8aa-d7c09374fcc5
f-cd2c0b6d-a21e-4c9c-aeb0-f4317c04878d
f-1eb98e53-8503-491d-b5c0-f317dbd2f762
f-576d7446-ba77-457d-978f-30311328eaf5
Can you make a voice call?
