Galaxy A36 5G
Samsung Galaxy A36 5G
f-812d5610-8194-4ec8-b506-90b529bfae86
f-b7e6b3b9-e273-4279-ac76-d55e69c1da4b
f-f60aecfd-404a-4afb-94cc-54908b0a2b83
f-f9592191-6d56-4940-bef6-f70e74a5eb9a
f-9749a3ca-5ffe-48ad-be00-1442977c552d
f-97259afc-1d56-441b-a133-f309d8161d44
f-a2eed512-727c-4431-b895-f721aaa32a99
f-1cd5043a-0ec5-4201-8a34-404ef25efad6
Can you make a voice call?
