Samsung Galaxy A40
Solution 1 of 3: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Step 1 of 9
Step 2 of 9
Press Connections.
Step 3 of 9
Press Connections.
Press Wi-Fi.
Step 4 of 9
Press Wi-Fi.
Step 5 of 9
Step 6 of 9
Press Advanced.
Step 7 of 9
Press Advanced.
Step 8 of 9
Press the indicator next to "Switch to mobile data" to turn the function on or off.
Step 9 of 9
x
Get information on
Or select
Another device
