Galaxy A52s 5G
Samsung Galaxy A52s 5G
f-0a1fd46a-cdde-4863-bdd2-fe517e74f136
f-7608ba8c-9348-49fc-8589-55fd3855999d
f-0e274c24-d65d-4dee-ba7d-b75daf76b535
f-c1dcfee0-e618-4f5c-9816-d2ebc317799c
f-253a777b-d3e3-4391-810a-ca506336ed51
f-fa5a9867-670a-41f4-ab92-3bffd09535ff
Can you use Wi-Fi?
