Galaxy A53 5G
Samsung Galaxy A53 5G
f-aa99f168-13a3-4c8d-9d4d-8fca574147db
f-ad92b3c8-2c9c-4edc-8650-e24efb7ec2b6
f-f4245a5d-bb42-466f-b47d-080a5969a3bf
f-b5c4bc34-ead9-4975-835a-1b48b34086d1
f-712c9c1e-a8f4-4dfd-94b9-dc67fddc676a
f-2ab82977-33e4-4e39-8be2-bbb13982f000
Can you make a voice call?
