Galaxy A54 5G
Samsung Galaxy A54 5G
f-128d3d7e-b07c-4031-b99e-50209343bd76
f-1e3b7ecb-a885-4988-b754-381e8698bdb1
f-ff6ded69-f666-4d13-bd6a-7ba1262c141d
f-224aeba4-deb3-4395-9486-7520dab7d3f1
f-2ba1a0dc-8c08-4606-8a7f-4f173e4397f9
f-65104958-72fb-4a7e-9ac0-49ec07d43c13
Can you make a voice call?
