Galaxy A55
Samsung Galaxy A55
f-4990cbc5-dc2f-4ffc-9015-a9296cf8a4e8
f-fe532214-fa39-4f5b-ab7b-c7ade27136b2
f-292f7946-617b-4f81-8590-e360f9c30277
f-069ccbec-fdf6-42d5-adfd-c1e1b2fd9635
f-5570e54d-c5f6-43c3-a354-ab0c5af73369
f-319e84f9-01d6-42dc-a3cd-1a5cd5d831d8
f-bfbb80df-0a7d-48ec-8fbc-b7890d5bdc19
f-7bd9e5b5-1a5d-49c7-8d0f-99104f7c5d61
Can you make a voice call?
