Galaxy A56 5G
Samsung Galaxy A56 5G
f-2ef72e27-e782-49f1-b7d1-1e515fc80731
f-fc991117-191b-412c-852a-aa0ba255d9ad
f-243ec78f-fd15-4f3a-9b66-9f18bebb0f1c
f-6842206d-0e42-492e-a7c1-a7b4068abd6e
f-abb3e9d3-e9bf-4b5b-9129-9641e34fd6ea
f-8f71adad-6d4d-4f46-9aec-3b785f84502b
f-e7861e84-21bd-4513-a9f4-603509899c17
f-06cce795-9fa8-4d7a-811a-0058fd901cf6
Can you make a voice call?
