Samsung Galaxy A56 5G
Selecting dual SIM settings
When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Press Connections.
Press SIM manager.
Press the required price plan.
Press the indicator to turn use of price plan on or off.
If you turn on use of the price plan, press Turn on.
If you turn off use of the price plan, press Turn off.
Press the Return key.
Press Calls.
Press the required setting.
Press Messages.
Press Mobile data.
