Galaxy A7 (2018)
Samsung Galaxy A7 (2018)
f-767f2e15-be45-4799-b91e-bdfbf2eba1e3
f-e0e79a71-916c-42af-8d07-9ce8362810fc
f-b72b608c-76b0-4a95-83e4-167d8f0cf60b
f-25c68b62-abc3-4d7a-a99c-b53242edd50e
f-ca2f1384-417e-4fbf-8156-f72471499b91
f-34a5f2e4-a970-4640-90d2-f477d913add9
Solution 4 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
