Samsung Galaxy A7 (2018)
Solution 3 of 3: Your phone doesn't turn on correctly
Before you can turn on your phone, you need to insert your SIM into your phone.
If you're asked to key in your PIN, do so and press OK. The default PIN is 1111.
Press and hold On/Off until a pop-up menu is displayed.
Press Power off.
Press Power off.
