When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Press Connections.
Press SIM card manager.
Press the required SIM.
Press the indicator to turn use of the SIM on or off.
Press the Return key.
Press Calls.
Press the required setting.
Press Text messages.
Press Mobile data.
