Samsung Galaxy A8 2018
Solution 1 of 3: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Press Connections.
Press Connections.
Press Wi-Fi.
Press Wi-Fi.
Press ADVANCED.
Press ADVANCED.
Press the indicator next to "Adaptive Wi-Fi" to turn the function on or off.
x
Get information on
Or select
Another device
