Galaxy Chromebook Go
Samsung Galaxy Chromebook Go
f-a0982606-bb3b-47ee-83ae-4e3f6fa42846
f-88d9349b-98fa-4047-94a1-2e30db4f6985
f-18983dad-a854-4f7a-b794-d373957f26b9
It's not possible use the fingerprint sensor on my laptop
Solution 1 of 2: There is dust or dirt on the fingerprint sensor
If there's dust or dirt on the fingerprint sensor, it may prevent it from registering fingerprints.
Clean the fingerprint sensor using a wet wipe or a damp cloth and finish using a dry cloth. Remember to turn off your laptop and remove the charger from the charging port before you start cleaning the touchpad.
