Galaxy Chromebook Go
Samsung Galaxy Chromebook Go
f-a0982606-bb3b-47ee-83ae-4e3f6fa42846
f-88d9349b-98fa-4047-94a1-2e30db4f6985
f-18983dad-a854-4f7a-b794-d373957f26b9
It's not possible to use Wi-Fi
Solution 1 of 5: No connection to a Wi-Fi network is established
You can connect to the internet using either a mobile network or a Wi-Fi network.
Find an opener for the card holder. Insert the opener into the small hole in the SIM holder.
Step 1 of 18
Please note that your laptop only supports nano SIMs.
Remove the SIM holder from your laptop.
Step 2 of 18
Turn your SIM so the angled corner of the SIM matches the angled corner of the SIM holder and place your SIM in the SIM holder.
Step 3 of 18
Slide the SIM holder into your laptop.
Step 4 of 18
Click the menu field.
Step 5 of 18
If your SIM is locked, click Not connected.
Step 6 of 18
Click Click to unlock.
Step 7 of 18
Key in your PIN and click Unlock. The default PIN is 1111.
1111
1111
Step 8 of 18
Click the close icon.
Step 9 of 18
When you're connected to a mobile network, the mobile network icon is displayed at the bottom of the screen.
Step 10 of 18
Step 11 of 18
Click the settings icon.
Step 12 of 18
Click the indicator next to
Step 13 of 18
Click the indicator next to "Wi-Fi" to turn on the function.
Click arrow right.
Click arrow right.
Step 14 of 18
Click arrow right.
Click the required Wi-Fi network.
Step 15 of 18
Key in the password for the Wi-Fi network and click Connect.
Step 16 of 18
Step 17 of 18
When you're connected to a Wi-Fi network, the Wi-Fi icon is displayed at the bottom of the screen.
Step 18 of 18
