Samsung Galaxy J4+
Selecting dual SIM settings
When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Step 1 of 14
Step 2 of 14
Press Connections.
Step 3 of 14
Press Connections.
Press SIM card manager.
Step 4 of 14
Press the required SIM.
Step 5 of 14
Press the indicator to turn use of the SIM on or off.
Step 6 of 14
Press the Return key.
Step 7 of 14
Press Calls.
Step 8 of 14
Press Calls.
Press the required setting.
Step 9 of 14
Press Text messages.
Step 10 of 14
Step 11 of 14
Press Mobile data.
Step 12 of 14
Press Mobile data.
Step 13 of 14
Step 14 of 14
x
Get information on
Or select
Another device
