Samsung Galaxy Note10
Selecting dual SIM settings
When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Step 1 of 14
Step 2 of 14
Press Connections.
Step 3 of 14
Press Connections.
Press SIM card manager.
Step 4 of 14
Press the required SIM.
Step 5 of 14
Press the indicator to turn use of the SIM on or off.
Step 6 of 14
Press the Return key.
Step 7 of 14
Press Calls.
Step 8 of 14
Press Calls.
Press the required setting.
Step 9 of 14
Press Text messages.
Step 10 of 14
Step 11 of 14
Press Mobile data.
Step 12 of 14
Press Mobile data.
Step 13 of 14
Step 14 of 14
x
Get information on
Or select
Another device
