Samsung Galaxy Note10+ 5G
Using music player
You can use the music player to play audio files you have transferred to your phone.
Step 1 of 17
Press Play Music.
Step 2 of 17
Press Play Music.
Step 3 of 17
Press Music library.
Step 4 of 17
Press the required category and go to the required audio file.
Step 5 of 17
Press the required audio file.
Step 6 of 17
Step 7 of 17
Press the upper or lower part of the Volume key to adjust the volume.
Press the song title at the bottom of the screen.
Step 8 of 17
Press arrow right to go to the next audio file.
Step 9 of 17
Press arrow left twice to go to the previous audio file.
Step 10 of 17
Press the repeat icon to turn the function on or off.
Step 11 of 17
You can choose whether you want the music player to repeat one or more audio files.
Press the shuffle icon to turn the function on or off.
Step 12 of 17
Step 13 of 17
Press Add to playlist.
Step 14 of 17
Press NEW PLAYLIST.
Step 15 of 17
Press NEW PLAYLIST.
Key in a name for the playlist and press CREATE PLAYLIST.
Step 16 of 17
Step 17 of 17
x
Get information on
Or select
Another device
