Galaxy Note20 5G
Samsung Galaxy Note20 5G
f-0ae872b5-d831-42f5-89f9-be76181212c3
f-65e7adcb-25f8-46c9-9ea3-94d1bc20a1aa
f-a4788640-b53b-4319-b40b-3f55f22996dc
f-de32e890-453a-4b10-9176-4a07c53c7572
f-a4e7cf9c-a9cc-45b9-96a8-78c9edbc5d49
f-d27342e7-8e8d-4980-967e-b6f86d1739b1
Using your phone as Wi-Fi hotspot
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Step 1 of 18
Step 2 of 18
Press Connections.
Press Connections.
Step 3 of 18
Press Connections.
Press Mobile Hotspot and Tethering.
Step 4 of 18
Press Mobile Hotspot.
Step 5 of 18
Step 6 of 18
Press Configure Mobile Hotspot.
Step 7 of 18
Press the field below
Step 8 of 18
Press the field below "Network name" and key in the required name.
Press the drop down list next to
Step 9 of 18
Press the drop down list next to "Security".
Press WPA2-Personal to password protect your Wi-Fi hotspot.
Step 10 of 18
The password prevents others from accessing your Wi-Fi hotspot without your approval.
Step 11 of 18
Press the field below "Password" and key in the required password.
Press Save.
Press Save.
Step 12 of 18
Press Save.
Press the indicator below
Step 13 of 18
Press the indicator below "Mobile Hotspot" to turn on the function.
Step 14 of 18
Step 15 of 18
Step 16 of 18
Step 17 of 18
Step 18 of 18
