Samsung Galaxy Note20 5G
Solution 3 of 3: Your phone doesn't turn on correctly
Before you can turn on your phone, you need to insert your SIM into your phone.
Press and hold the Side key until your phone is turned on.
If you're asked to key in your PIN, do so and press OK. The default PIN is 1111.
Press the power off icon.
Press Power off.
Press Power off.
