Galaxy Note20 Ultra 5G
Samsung Galaxy Note20 Ultra 5G
f-a6d66dc4-6c9a-499b-aab7-ca2636fa0f7d
f-31e1df8d-ccad-4120-8009-9e21a418f3c4
f-52c6689d-ff91-4af9-b6a3-b5df2465be59
f-9bcd2aab-30dd-405e-b929-df3a4837aba8
f-1123f0e1-a7aa-4ce8-8bde-c490ed3d6c6e
f-472ac829-579f-4508-9867-2750d5057764
Can you make a voice call?
