Galaxy Note20 Ultra 5G
Samsung Galaxy Note20 Ultra 5G
f-a6d66dc4-6c9a-499b-aab7-ca2636fa0f7d
f-31e1df8d-ccad-4120-8009-9e21a418f3c4
f-52c6689d-ff91-4af9-b6a3-b5df2465be59
f-9bcd2aab-30dd-405e-b929-df3a4837aba8
f-1123f0e1-a7aa-4ce8-8bde-c490ed3d6c6e
f-472ac829-579f-4508-9867-2750d5057764
Solution 1 of 4: GPS position usage for applications is turned on
Step 1 of 12
Step 2 of 12
Press Location.
Press Location.
Step 3 of 12
Press Location.
Step 4 of 12
Press App permissions.
Step 5 of 12
Press the required app.
Step 6 of 12
Press the required setting.
Step 7 of 12
Press the Return key twice.
Step 8 of 12
Press Google Location Accuracy.
Step 9 of 12
Step 10 of 12
Press the indicator next to "Improve Location Accuracy" to turn on the function. If you turn on the function, your phone can find your exact position using the GPS satellites, the mobile network and nearby Wi-Fi networks. Satellite-based GPS requires a clear view of the sky.
Step 11 of 12
Press the indicator next to "Improve Location Accuracy" to turn off the function. If you turn off the function, your phone can find your exact position using the GPS satellites but it may take longer as there is no access to supplementary information from the mobile network or nearby Wi-Fi networks.
Step 12 of 12
