Samsung Galaxy S20 5G
Using your phone as Wi-Fi hotspot
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Press Connections.
Press Mobile Hotspot and Tethering.
Press Mobile Hotspot.
Press Configure Mobile Hotspot.
Press the field below "Network name" and key in the required name.
Press the drop down list next to "Security".
Press WPA2 PSK to password protect your Wi-Fi hotspot.
Press the field below "Password" and key in the required password.
Press Save.
Press the indicator below "Mobile Hotspot" to turn on the function.
