Galaxy S20 FE
Samsung Galaxy S20 FE
f-4b30c5e8-8f8d-406d-8c9e-73bb397e9190
f-79d3700b-352b-421b-a167-4f3840c06a22
f-b60ac41d-a31a-44fc-b919-299c1ffe418e
f-24446408-8912-450e-84ae-57788cab6137
f-4e6db3eb-a86c-4af5-872a-b92179517388
f-b55684c0-3d53-49a6-8f1d-5c5f79e3a4f5
Solution 4 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
