Galaxy S20+ 5G
Samsung Galaxy S20+ 5G
f-3bbd160d-f828-46c2-988c-b2f92d3f1242
f-bad6b79b-b520-4e7b-b2c4-52a613242be1
f-e3ac38f1-9af9-4901-8f49-e9092a24861e
f-59d134b3-4c3f-475d-b2d6-d5a45e671961
f-81d0d4e6-1ac3-4e96-884a-f8326052ad65
f-77af4f78-6df9-40cf-82cb-3fa7d45a4d34
Solution 1 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
