Galaxy S20+ 5G
Samsung Galaxy S20+ 5G
f-3bbd160d-f828-46c2-988c-b2f92d3f1242
f-bad6b79b-b520-4e7b-b2c4-52a613242be1
f-e3ac38f1-9af9-4901-8f49-e9092a24861e
f-59d134b3-4c3f-475d-b2d6-d5a45e671961
f-81d0d4e6-1ac3-4e96-884a-f8326052ad65
f-77af4f78-6df9-40cf-82cb-3fa7d45a4d34
Solution 2 of 4: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Step 1 of 9
Step 2 of 9
Press Connections.
Press Connections.
Step 3 of 9
Press Connections.
Press Wi-Fi.
Press Wi-Fi.
Step 4 of 9
Press Wi-Fi.
Step 5 of 9
Step 6 of 9
Press Advanced.
Press Advanced.
Step 7 of 9
Press Advanced.
Step 8 of 9
Press the indicator next to "Switch to mobile data" to turn the function on or off.
Step 9 of 9
