Galaxy S20 Ultra 5G
Samsung Galaxy S20 Ultra 5G
f-a8a4a997-5738-4064-990f-a8996a5eb19f
f-7c9cb320-169a-49a5-af96-87c4179299b8
f-cd5d6fa2-e277-4ce0-ae97-1ce9846dbfbe
f-a49b8802-db24-4ba1-a510-976efc6e50f5
f-c8394c3a-1083-4cfd-93fd-1c28b3227393
f-eeb6a9ba-078e-4d3c-9f88-19d11538e7ec
Can you make a voice call?
