Galaxy S21
Samsung Galaxy S21
f-2e656601-c0e6-4903-8b14-ba442e5576f1
f-1ec9edfb-3f30-4d72-a4be-a3c86e530c42
f-8fb727c3-7b58-4c52-8e49-d92f0af8f82a
f-01716f84-c1ed-42f0-9a1c-8b6da44abbb4
f-42d8e4d0-fd79-4112-bae4-c9c335a3d192
f-fc9353fb-f0df-4b86-a026-3bae438f3974
Can you make a voice call?
